NEW SALES INCENTIVE FOR SELECT STATES
DON'T KNOW IF ANYONE IS INTERESTED BUT WE ARE RELEASING A NEW PURCHASE INCENTIVE IN THE BEGINNING OF NOVEMBER FOR 2 FREE SEASON SKI PASSES FOR THE PURCHASE OF SELECT SUV's BY RESIDENTS OF SELECT COUNTIES IN THE STATES OF:COLORADO, UTAH, AND SELECT COUNTIES OF: WA, ID, MT, CA, and NV.  IF YOU WOULD LIKE MORE INFO...GIVE ME A HOLLER.
Name of Program:  Ski Chevy
Program Summary:  Extend valuable purchase offer for Chevy SUV's during the ski season
There is a program headquarters set up for this program and is advertised on all TV ads and print materials.
Target Audience:  States of Colorado, Utah, counties of WA, ID, MT, CA, and NV
Offer:  Purchase or lease an eligible 2001/2002 Chevy SUV (see list below) and receive 2 season passes (or other season tix offer, see list below) to the participating resort in that area.
State of Colorado: Purchase/lease a 2001/2002 Chevy Avalanche, Suburban, Tahoe, TrailBlazer, Blazer, or Tracker, and receive 2 season passes to Copper Mountain Resort.
State of Utah: Purchase/lease a 2001/2002 Chevy Avalanche, Suburban, Tahoe, TrailBlazer, Blazer, or Tracker, and get 2 season passes to Park City Resort.
Eligible counties of WA, ID, MT: Purchase/lease a 2001/2002 Chevy Avalanche, Suburban, Tahoe, Trailblazer, Blazer, or Tracker, and receive 2 season passes to the Harbor owned Resorts (Stevens Pass, Mission Ridge, and Schweitzer Resort).
Eligible counties of Northern CA, NV: Purchase/lease a 2001/2002 Chevy Avalanche, Suburban, Tahoe, TrailBlazer, Blazer, or Tracker and receive a choice of 2 season passes or a Family Learn To Ski Packet to Kirkwood Mountain Resort.
Eligible counties of Southern CA: Purchase/lease a 2001/2002 Chevy Astro, TrailBlazer, Blazer, Tracker, or S10 and receive a family season pass for 2 adults and 2 children to Mountain High Resort.
Dates of Offer:  November 1, 2001 through February 28, 2002
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
