2003 Tahoe 4.8 Flush
red29
I am questioning if it is ok to use the drain plug that is attached to the radiator to drain the coolant from the radiator and flush my cooling system. I was informed by a GM Goodwrench tech that removing the plug will cause damage to the radiator in some instances. I have never flushed the system for the past 145K miles and just plan on changing out the hoses and thermostat this weekend. Any and all feed back would be greatly appreciated.
I usually take them out or loosen them depending on the style. I've broken the valve itself but never caused any dammage to the radiator. It's not a bad idea to call around and find a replacement plug just incase you do break it. If you do break it Murphy's law states that you will break it after all the stores are closed. I don't know if you can find the right replacement part in the after market but I know both dealers I've worked at and a few others where I know people all stock the plugs. It's a pretty cheap part to just have incase you need it.
I have an 05 Silverado 4.8 and i didn't mess with the drain plug.
Drain the coolant from the lower hose. Unbolt the thermostat housing and remove the old thermostat. What I do is then snip out the plunger from the old thermostat and replace it in the housing. This way you've now got a free flowing circuit.
Fill the radiator with distilled water ($1.29gal at the grocery store), run for a couple of minutes, shut off engine, drain from lower radiator hose and repeat. After the second fill it should be draining clear so you know you've got the vast majority of the old coolant out. Pop your new thermostat in, then fill with the proper mix of DexCool. Just remember that the block will have fresh distilled water so you will need to add a gallon of 100% Dex then finish fill with 50/50.
After 145k you may want to unbolt and hose out your coolant overflow tank as it's most likely pretty gunked up as well.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
