Help 2008 Silverado Won't Start
mcnu0045
Help!
I have a 2008 silverado 1500. Somehow the security system got triggered and it will do everything but start. The fuel pump Primes, the horn honks when i enable and disable the system with the FAB, but it won't start. Does anyone know how to reset it? I hit the on star button to see if they could disable whatever it is, but to no luck.
thanks
I don't know how to disable it, but you might want to try your spare key. It might be that your key lost it's coding. If that doesn't work, call Onstar, and have them tow you to the dealer. The truck is under warranty, and they will take care of you. Let us know what they tell you.
-Al
The manual should detail what to do if the security system is triggered. I'd think it would reset with the fob. Try holding the panic button down, then turning it off. Maybe that will clear it.
It was a 2 amp fuse (#35) that went. It's such a small fuse that I didn't see the break in the wire under the poor light in the garage the first time I looked at it. Thanks for the advise guys!
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 280 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
