jphaase Posted September 16, 2008 Posted September 16, 2008 Does anybody know the part number to the nut that goes with the tire pressure sensor so it can be mounted to the wheel. The illustrations don't show a nut as part of the assembly. I have no idea as to how it is installed into the wheel since I was never able to really look at them prior to the wheels being stolen. New wheels will be here tomorrow and I want to make sure I have everything needed to get them installed.
MS3DALE Posted September 16, 2008 Posted September 16, 2008 The GMT900 pickup tire pressure sensors don't use nuts to hold them in,They look just like regular valve stems that "push" through the hole.
jphaase Posted September 16, 2008 Author Posted September 16, 2008 The GMT900 pickup tire pressure sensors don't use nuts to hold them in,They look just like regular valve stems that "push" through the hole. Then I guess I got the wrong sensors. Damn GMPD online catalog.... Being that is the case, what is the correct part number for the sensors used on the GMT900?
jphaase Posted September 16, 2008 Author Posted September 16, 2008 Found the part number for the valve stem. Now I just need the sensor part number.
jphaase Posted September 17, 2008 Author Posted September 17, 2008 After doing some major searching I have finally came up with the most current part number (its been superceded a couple of times). I am just posting it up to help someone that may need it in the future. GM Tire pressure sensor part number: 15922396 GM Wheel service kit (replacement stem): 15263240 Also part numbers for the actual manufacturer, Schrader-Bridgeport. Sensor w/stem : 20153 Valve stem only: 20008 These are available at Oreilly's, Autozone, etc. Price is pretty much the same there as at the dealer, $53 vs. $57.
