Map Sensor
I have a 2003 Tahoe 4.8 2wd 145k. When would you know if a MaP Sensor is going bad?? Any ideas would be greatly appreaciated.
Thanks
Red29
I have a car hip scanner on my rig at all times and has never read any Check engine codes. Just have some hesitation when when i accelerate quickly. i will unplug and test that theroy tomorrow.
thanks
Red29
FYI
i was able to remove the MAP sensor from the intake manifold and found that the inlet part of the sensor had a film of carbon build up cover it. A few squirts of carb cleaner took care of that as well as the hesitation i was getting at idle.
Red29
