Temp/direc Rearview Problems
2003 Silverado temp/direction mirrow will stay off for long periods and then just come on...then off again etc...I would appreciate some help or direction...thanks.
check the harness near the headliner and make sure it is connected firmly
thanks...I checked the harness both on the mirrow ..everything appears to be ok...still no luck...anything else I can check I would appreciate the help on....
Mine does it only when it rains hard.... does yours do it all the time?
it was fine and then one day it went off and from then on it just comes on and then goes off again for no ryhme or reason...I have a feeling it may be either the mirror itself or the sensor...I guess I will start with the sensor and go from there....
If it operates like the 02 models the sensor only controls the temp portion of the display. The compass portion is actually part of the rearview mirror itself so it's obvious the sensor isn't causing the display issue. Unplug the connector on the back of the mirror and inspect it for loose or pushed back pins. I had the same problem yesterday and reached back and moved the wires slightly and the display started working again.
