knotttty59 Posted September 21, 2008 Posted September 21, 2008 Hi I have been looking for help in these forums... seems I have a odd one here. When travelling between 50 and 60 mph I have a shake vibration from the rear.. its not always there but most of the time ..worse when in a high speed curve. I have 20 aftermarket wheels and a drop hanger kit approx 1.5 inch drop. so far I have put a new support bearing on the drive shaft....balanced the wheels..axel shims 2.5 degree's..new rear shocks.. checked the brake clips..none there..its doesnt seem consistent enough for a drive shaft or axel issue... any help would be greatly appreciated Thanx Knotttty59
knotttty59 Posted September 22, 2008 Author Posted September 22, 2008 Hi I have been looking for help in these forums... seems I have a odd one here. When travelling between 50 and 60 mph I have a shake vibration from the rear.. its not always there but most of the time ..worse when in a high speed curve. I have 20 aftermarket wheels and a drop hanger kit approx 1.5 inch drop. so far I have put a new support bearing on the drive shaft....balanced the wheels..axel shims 2.5 degree's..new rear shocks.. checked the brake clips..none there..its doesnt seem consistent enough for a drive shaft or axel issue... any help would be greatly appreciated Thanx Knotttty59 Well I went and put my old tires and wheels on today stock 16 inchers... that was a big help... went to a chassis shop I know here and he said the MOnroe matic shocks ride like a tank if you even lower your truck a little... ill keep on trying to make it perfect..
