Reg Cab Denali
Hey Guys,
This is one for the GM tech guys.
I have an 08 Sierra Regular cab. I recently managed to royally screw up my bumper, foglight fairing, foglights, lower appearance fairing, and the black wraparound plastic above the bumper.
I want to make my truck into a regular cab denali. If I go and order the new grill, bumper, fairings, foglights and wraparound, will it fit? I also want to do this to the rear bumper and tail lights.
WILL THIS STUFF FIT?
Let me know, if you know!
Cheers,
Mark Binns
Assuming you are talking about the 2008, everything should mount right up. The bumpers are the same as well as the bumper cap. Grill and tail lights are a direct swap also. You can even buy the door molding with the chrome strips, some chrome handles, some painted mirror caps and the badges and go all out.
What wheels do you have on the truck? Without the right wheels, the Denali look will be worthless.
Can we have some pictures of your ride to get an idea what you are working with? Also, how exactly did you damage it?
Just go ahead and do it. I just put the Denali grille on mine this past weekend and it adds to the look, even if you don't get around to changing the bumper, it still looks good.
+1 and it could come in handy as the worlds largest cheese grater too. :thumbs::)
Sorry, I love everything about the Denali, except the cheese grater grill and the AWD.
