Newb From Canada..
TimoSLT
New Member from Ontario..
I just picked up a 2008 Sierra SLT Crew Cab about a month ago. I am loving this truck and can't wait to start some mods. I've done a little bit of searching on the site when i can access the web, and this looks like a great home..
i may need some good shops in Michigan to go to get parts from. i'm only 2 hours from port huron, and the mark-up on goods here is ridiculous.
Thanks for having me guys
Cheers :puke:
Tim
hahaha i know i know pics will be up after this weekend... i am doing a mini shoot with my dad's 07 chev and our 78 bird, so there will be a little bit of everything for ya!!
Cheers :thumbs:
Tim
If you need an address in Port Huron where you can get your stuff delivered let me know. They charge $5 per package and will call you when its in.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
