Center Console Broken.. Need Help!
I have a 2004 Silverado extended cab. The center console flips up to make a middle front seat. The hinges on the lid of the console have broken off. I googled this problem, and it seems to be pretty common on this type of console. I contacted my local dealer, and they informed me that I couldn't just buy the lid; that I had to buy the entire jumper seat for $350. I also tried local junk yards, but none have what I am looking for. Ebay has some, but they are not that much cheaper than the dealership after you factor in shipping cost. So, instead, I bought a piano hinge, and attached it to the back of the console. But, when I thought I was finished, I noticed that the latch would not release the lid when I pushed the open button. I pulled the cover off the latch, and there is a little plasic piece that holds the open button in place that has broken off.
So here are my questions:
Anyone have this problem, and have any suggestions to fix this?
Any suggestions on any other type of consoles I can place there instead that won't cost me an arm and a leg? It's not important that I keep the jump seat, I just want something that looks nice.
I see that you've double-posted this and are asking for an response within both threads, it's better to stick with just 1.
See my response in your other post
  • 3 years later...
http://www.ebay.com/itm/230711286731?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
I also had to deal with this all the gm parts houses wanted an arm and leg wrecking yard were out or had broken ones
so i built this kit
here is a link to ebay were it is for sale or email me direct
this kit is made from metal and will not break
[email protected]
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
