Compatible Body Panel
hypothetically speaking, if someone wanted to use the front end of an 03-05 Silverado on a 00-02 body style Tahoe would it just be a bolt on deal excluding normal paint/prep? This would include the fenders, hood, front bumper, grill, and headlights.
Yep sure would,As a matter of fact the '03-'06 Tahoes/Suburbans built for the Mexican market had the same front-end on them as the pickups did.
You would also have to change the bumper/frame brackets and headlight mounting brackets.
The radiator support might also require changing.
Theres probably other "little" things that would need changed also,but those are the few that come to mind right off hand.
Agreed.
It would work as long as you use a complete clip with rad support and all bracketry. We did a monster lift 4x4 05 Suburban with a truck front end a few years back and it went really well. If I remember right, we had to tinker with the front wiring harness but all it took was a little homework and plug swapping. Original radiator and condenser were used.
