Oil Filters For The Gmt900
I checked the Wix website when I bought my GMT900 truck, and there was a different number. It is 57060, and it is a smaller filter then the larger one for the GMT 800. Here are the specs for it:
Part Number: 57060
UPC Number: 765809570603
Principal Application: Various GM, Saturn, Saab (07-08) All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Outer Diameter Top: 2.970
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 15
Anti-Drain Back Valve: Yes
Beta Ratio: 2/75=10/25
Max Flow Rate: 10-12 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.750 2.410 0.270
Don't try to use the 51522 on a 900 series truck. The thread size is different.
thats what i was wondering. thanks
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
