Gmt900 Window/mirror/lock Switches
I spilled some fuggin coffee all over the switches. Wanted to know of the panel they lie in is removable in any way. I wanted to get in there and clean it up. Hoping there is a way rather then removing the entire door panel... Let me know! Thanks!!
Yep, gotta remove the grab handle first but they should pop right off the door panel...There's a little slot on the bottom of the grab handle which'll remove the middle trim piece to expose the two bolts to remove.
This is on a LT1 though, not sure of upper trim levels but I have 4 window switches and the mirror switch.
