Build Sheets
sirzenman
hey can some one help me? I know this a great GM truck site and everybody seems to be able to get information that others need, but I have hit a brick wall, and I'm hoping some one out there can help me get the information i need in regards to a copy of my original build sheet of my GM Monte Carlo! Vin #2G1WZ151649429462. this site seems to get the information accurately and I need any or all the help needed to get any information pretaining to my built sheet. i would be very appreciated for any responses. I'm hoping you can help a fellow GM owner! sirzenman
Hi there and welcome to GM Trucks! :loser:
What kind of information are you looking for from the build sheet? I know we aren't allow to post the build sheet information anymore.
darin, thanks for answering, I quess where i can get mine for my vehicle. I seen while on line the whole sheet regarding someone else's and I thought I could get the same thing. If we can not print over this forum then where can i get the information from? I'm trying to get a new car listing sticker and they need the information on that build sheet to formulate the correct and to authenic my copy of my window sticker. any other directions i would be appreciated! carlton
We used to be able to post the build sheet information but the admins of the site were asked to prohibit that sort of information from being published.
Any GM dealership is able to print that information for you. So you know a good sales person at a GM dealership, they should be able to do it for you.
Carlton, you should be able to get one from a GM (Chevy or GMC) Dealer, that's what I did.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
