1999 Gmc Diesel 6.5liters
Doc 1953
Problem with 1999 GMC Diesel 6.5 liter engine.
Starts up right away but white smoke for about a minute then clears up.
& Ideals good.
But when try to get any RPMs out of it the max is 1200 rpm & starts to push white smoke. Had a shop test for trouble codes they came up with these six codes
( PO126B, PO216B, PO236D, PO238B, P1216D, P1217D ) Not sure were togo or what to replace. I think the Injector pump needs to be replaced. I hoped by scanning for codes it would confirm the injector pump.
Thank you Doc 1953
I have the codes, unfortuately I am not well verse with diesels. One Thing I would check is the coolant and the oil. See if one another have mixed. You may have a bad head gasket.
P0126
Insufficient Coolant Temperature for Stable Operation
P0216
Injection Timing Control Circuit Malfunction
P0236
Turbocharger Boost Sensor A Circuit Range/Performance
P0238
Turbocharger Boost Sensor A Circuit High
P1216
Pedal Position Sensor C Circuit High Input
P1217
Pedal Position Sensor C Circuit Intermittent
& Ideals good.
Thank you Doc 1953
P0126
P0216
P0236
P0238
P1216
P1217
Thank you for your reply yes the codes you sent back maches with the ones I got back from the shop. The oil & coolant are both good. I think either the fuel Injector pump or the pmd may be the problem. Causing these codes to come up saying there is a problem with the other sensors or circuits. thank you agian
    RichardRS
    RichardRS
  • Who's Online   5 Members, 0 Anonymous, 954 Guests (See full list)
