P0332 Knock Sensor 2002 Sierra..help !
Thank you for the walkthroughs. This will definitely help me once I get around to replacing the parts. Anyone happen to have the part numbers handy for the sensors, gaskets and wire harness on a 2003 Tahoe (5.3L)? I found the following part numbers (couldn't find wire harness) and I wanted to double check them:
GM Part Number: 89060413
Manifold Gasket
GM Part Number: 12589867
Knock Sensor
WIRE HARNESS 12601822
alright... i'm SO glad i found this. google FTW! haha.
anyhow, i'm no slouch when it comes to working on motors - i figure if i can change plugs on a trailblazer i can nearly do anything. :cheers: that being said, i'm looking at gmgenuineparts.net and found in this thread the part number for the harness.
can someone tell me what the part number are for the parts i need? i cleared my code this morning, let it get all "monitors" back to ready. i got her inspected (dang sneaky cops) and on the ride back home after passing inspection, the light comes on again - shorlty after gunning it a bit. anyhow, i'm sick of this error, and just want to fix her. plus it looks like it would be a good idea to dig down in there a do a little cleaning anyhow.
so in short - what are all the part numbesr from one place? if gmgenuineparts.net is the "cheap place" then lay em on me. if not, just lemme know what i need to order and from where and i'll snap some shots along the way (for the SUPER noobs like myself that aren't afraid of tackling something that's prolly an all day job). thanks y'all!!
~Agg
alright... i think i found it. sorry about that - did a little more "in depth" reading. reading for the win! anyways, just wanna double check that i need:
two sensors
one hardness
one set of new gaskets (2 pack)
thanks!
  • Replies 164
that's what I got ordered and received to do mine (coming in Xmas day with my daughter ;) )...the only other thing, which I didn't find, would be the valley pan gasket, but I'm hoping
I won't need it. I ordered all my stuff from Amazon at GREAT prices, except the harness, which I found on Ebay, also at a GREAT price!!!! Happy shopping:)
OH, I also ordered 2x Fel-Pro ES71190 Gasket Set, 2x Fel-Pro ES71192 Gasket Set for the fuel rails, but not sure I'll use them, and
a Fel-Pro 61070 FelPro Gasket for the Throttle body!!
are there other gaskets i WILL need, or is the intake one all i'll FOR SURE need?
from reading this thread, I got the feeling the throttle body would be necessary, and the fuel rails
depending on how they are dismantled...whether as a unit with the intake assembly or separately.
i'm hoping/planning on just taking the whole upper assembly off as a single unit. i guess we'll see what happens. haha. might have to do a little digging around in there first i suppose.
well I finally got to the job today, and all in all it went well...took over 7 hours, but for first time, I understand this is normal...my biggest delay was trying to remove the fuel lines from the fuel rail WITH the special tool...I wasted 2 hours trying to get them off(so my suggestion, remove them FIRST in case you need to seek help with them if that's the way you want to go), then decided to remove the rails and leaving them connected to the fuel lines, pulled up out of the way, and really not a problem as I had ordered the gaskets for the rails anyway, so they got used ;) other than this as a tip (vs removing the lines), everything else posted here in the thread was bang on. (I had to edit this post as I got my MAP and MAF mixed up in my head, and all in all I just forgot to CONNECT the MAP at the very back of the MI, so don't forget that one too like I did when reconnecting everything..it's easy to miss back there :) )
one concern though.... as soon as I removed the Manifold Intake, I noticed some wet oil on the back ports, then after tipping the MI up on it's side, I found a small puddle of oil had come out of it..if appears to have come in the PCV intake..I talked to a mechanic friend, and he said if I'm not eating any oil, and I never have, then it could just have been a build up
of excess taken in through the PCV line, and not to really worry about it...any thoughts on this?
  • 3 weeks later...
I finished the knock sensor replacement over the weekend. Following the great information from this post helped so much. Thanks for everyone that took the time to share the information. The intake and ports on the head had quite a bit of build up, any thoughts on what this is from? cheap, gas, bad PCV? Thanks again.
I just bought a 2002 GMC Yukon XL with 151,171 on the meter. After reading this post I figure I need to change the knock sensors. Is there a website I can go to where I can order all the parts I need at one time? I am planning on ordering:
2 knock sensors
knock sensor wiring harness
intake manifold gasket
and I will go buy cleaner and rtv from an auto parts store. Do I need valley pan gasket, throttle body gasket, and valley cover grommets?
I am looking forward to tackling this job. I am going to take many pics and post them if I can figure out how!
Thanks in advance!
Steven
2 knock sensors
Thanks in advance!
Steven
just take the part #'s from reading this post, and search the net, including eBay, and you'll find your best prices....I did really well with eBay for the harness and Amazon.com for the rest..REALLY!!!!!
I thought I wanted the valley pan gasket too, but after doing the job, I'm glad I didn't bother, but I did get the throttle body gasket, as it was cheap and easy to replace.
GOOD LUCK!!!! (and be sure to take note of my post above on the gas line fittings ;) )
Hi everyone!
I just joined the site because of the wealth of knowledge I have found on this topic! My knock sensors have been throwing codes for the past year or more and when i would have the code cleared, the CEL would often stay off for months at a time!
I'm finally at a point where I need to take the truck through emissions and I've decided to bite the bullet and fix the problem! I have washed the engine compartment in the past, so that very well could explain the cause of my problems. However, one would think that after hot summers and engine heat, the water would dry up and if there was still a problem with the KS's, the light would come on more often than it has for me. :-)
I've got a nice new garage now, so at least I can pull the truck in and have plenty of room to work! I'm hoping I see some of the same results that some of the rest of you have seen - mainly more power and better fuel economy - especially now that fuel is up around $3.20/gal here in the Seattle area again :-(
I'll post back with pictures and any additional comments/suggestions I may come up with in the process :-)
Thanks again!
Ryan
2 knock sensors
Thanks in advance!
Steven
Ok... Today I decided would be the day to tackle the job. Well, I got all the way to the fuel rail/injector step in the Haynes manuel and after realizing that I might not be quite cut out to do this job, I put it all back together and told my wife that I am going to let a professional do it!!! I am quite mad at myself for giving up, but our Yukon is my wifes primary vehicle and I didn't want to screw it up under my carport and have to call a tow truck to come get it on Monday! The next step was to take off those fuel lines and I was looking at them like a cow looking at a new gate. Thats when I realized that I was probably in too deep. Anyway, I am hiring a mechanic that works for a GMC dealer and does jobs on the side and I am going to watch him do it if he will allow me to shadow him. I am going to take plenty of pics and maybe even a video to post on here. Thanks for the advice!
sorry to hear that :lol: that's the same spot that almost got me till I realized I could just remove the fuel rails and leave them
intact with the fuel lines, and slip the intake manifold out from under the rails...it was actually pretty easy to do, and I already
had the new fuel rail gaskets, so I got to use them too! Those fuel lines can be a real bitch, and no one seems to have provided
any tricks for doing the difficult ones, even with the right tool.
Great thread! Since youve all got your thinking caps on, ponder this:
2005 2500HD 6.0l 125K miles
Okay so one day I get DTC p0332.. rear knock sensor... After reading the TSB, I jump right in. Seemed like a slam dunk-- the rear sensor was corroded/rotten and so while in there I replaced both sensors, made sure the harness was in good shape, siliconed the grommets, and replaced the intake manifold gaskets..
So I got it all back together and I am still getting the P0332 code. Man, what luck. So I do a little more investigating.. As per the GM troubleshooting flowchart, I:
- have ~95 Kohms resistance at BOTH sensors, (measured at the harness connector AND at the PCM harness connector)
- have continuity along the entire harness for both sensors
Everything looks normal.. So I start to suspect the PCM. Could it be?
So, I took apart the harness connector pigtail for the knock sensors, and swapped the wires, so the rear sensors was input for the front, and vice versa. If the computer still told me it was p0332, then its definitely the PCM.
Well it didnt! It threw a P0327 this time which is the front sensor. Good game, PCM. You win. Its the rear sensor still..
I have no qualms about opening it back up to fix the problem, but, I am not so sure what I am looking for. I know what you're thinking--- Replace the harness!! Well I would have if I had any issues with it but it was in "good" shape and I had good continuity/connection (maybe not good enough though?)
Even more baffling is that I am getting the exact same response/readings from both sensors. There is NO difference that I can tell. My cheap analog meter doesnt really register any output from the sensors (it must be too slight for the 10vac range) and with my digital meter, its bounces around at about .25 volts AC... (on both sensors)
Sure seems to me like I have a good harness and sensors.
Any ideas?
Thanks
Mike
Any ideas?
Thanks
Mike
there's probably still corrosion in the block where the sensor screws in. the harness is only one wire per sensor, right? if so, the sensor is using the block as a ground, so the sensor and its threads may be clean, but the threads in the block have to be gunked up.
i still have yet to tear into mine, so it's only speculation, but if you'll be tearing it apart again, it's worth a look and cleaning.
update: Fixed the problem.
The new sensor was defective! So yes, it does happen.
I had to remove the sensor to really test the output. With a sensitive DMM, you can easily see the output when you tap on the sensor with something (the other sensor works good for this)..
The "good sensor" was very consistent and gave good readings from .0025 to .0100 (approx) volts AC... the bad sensor had the correct resistance, but only put out about half the voltage, and it wouldnt sustain the output as well as the good sensor.. it would sometimes dip down to <.0015v and would have a hard time going higher, even with hard consistant knocking..
anyways it was a borg warner sensor from oreillys and they replaced it without issue.
Mike
    RSTRICK
    RSTRICK
  • Who's Online   4 Members, 1 Anonymous, 622 Guests (See full list)
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
