Tuners/fuel/power
Is there such thing as a programmer that doesent void youre warranty? this being said.. whats the best programmer for increases power and will regain my power from my tire change.. stock was 245.. and im getting 315's.
Yup :sleep:
(btw, it's been covered numerous times, and there are mixed opinions about programmers - around here a custom tune is the way to go)
Yup :sleep:
Will this still void my warranty?
Not trying to sound like a crabass, but my GOD!!! This is by far the number one question/topic on this site. USE THE SEARCH!!!!
Yup :sleep:
Yeah, and you know it's gotten bad when you actually miss the good 'ol "Which exhaust to buy" threads. :uhoh:
Yeah, and you know it's gotten bad when you actually miss the good 'ol "Which exhaust to buy" threads. :sleep:
At least with that there can be different opinions. :uhoh:
Well, unless Jeff gets a Corsa exhaust. Then it's all over! :eek:
At least with that there can be different opinions. :eek:
Well, unless Jeff gets a Corsa exhaust. Then it's all over! :cheers:
:eek::sleep::D
By the way, your avatar is freaking awesome.
:eek::sleep::D
Yeah, everytime I think about changing it, I look at it, then get distracted and forget what I was doing. :cheers:
Yeah, and you know it's gotten bad when you actually miss the good 'ol "Which exhaust to buy" threads. :D
At least with that there can be different opinions. :cheers:
Well, unless Jeff gets a Corsa exhaust. Then it's all over! :D
:cheers::uhoh::D
Yeah, everytime I think about changing it, I look at it, then get distracted and forget what I was doing. :lol:
Same here. Right now, it's lowering my Physics grade... :eek::sleep::eek:
