Tire Help
Hey I have an 08 ext cab 4wd and im looking at the truxx leveling kit im wanting to run 305/70/17s buckshot mudders and im wondering if anybody has any idea if this will work. Im also looking at 17" aftermarket rims and was wondering if changing the backspacing would help. Thanks.
