Maf Sensor
Does anyone know where I can get a MAF sensor for a 03 silverado for fairly cheap. I am planning on getting rid of the truck and want to fix my bad MAF sensor before I trade it in cuz I know they will really kill me on trade in even worse then they already are going to.
