Clunk Noise
For the last week or so, been hearing an intermitent clunk noise from what sounds like the rear-end of the truck. Mostly noticed it when pulling into my driveway (on a little bit of a hill).
Took a crawl around under the truck, nothing appears to be lose or anything....any ideas before I take it in?
I have had the same issue with my 01. I have a clunk when I first take off and I have also noticed a clunk when I tap the brakes real quick. I was wondering if you have figured anything out on yours. I plan on looking into mine over the weekend and/or next week so any advice would be great.
Thanks.
Sounds like a u-joint with a dry socket. Does it make a clunk when you first put it in gear? You mentioned clunking on a slight hill. U-joint is stiff it's not flexing anymore sounds like to me. Have someone stand and listen at the rear wheels when truck is put in gear, betting you will hear it clunking some. If so replace it with a spicer greasable joint.
While the u-joint would be my first guess as well, I've also heard that sometimes the spline shaft in the trans sometimes gets dry and will cause a clunking noise. Just something to consider.
I will def. look into u-joint issue. But its almost more of a suspention sound. To be more specific....I will be turning left into my driveway (only time ive heard it), when my passenger side rear wheel hits the dip at the end of the driveway is the only time it makes the "clunk" noise. weird!
Sounds like your rear diff locking after you go over the dip/bump in your driveway. Have had the same thing happen at my kids school parking lot, when turning left over a storm drain grate.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
