Looking For An Answer.
I have ask a couple of times before but still have got the answer I wanted. I have a 2008 Z71 Crew Cab LTZ with 265 65 18's.I would like to get bigger tires but I am not sure want size will fit on a stock truck with no lift. :thumbs:
If I am not mistaken, you can go up to 285 mm width without any interference.
However, your speedometer will be reading too low because the 285 tire will be taller, unless you go with smaller aspect ratio.
I Thought 285's Might Rub.
NOPE!
I have 285's on my truck on the stock 17's
never had an issue even when i take it off road
your speedomiter will be about 5 mph off but i haven't had a problem with that either
i drive the speed it says
Lots of people are running 285s in 17 inch tires. Not sure in 18s what will fit. (or what is available) You should be able to go up one size with minimal interference.
Try searching. There have been many discussions about this exact topic.
^^^--- That's the type of answers I found nearly every time I tried using the search on this forum. A lot of people saying search, but very few actual posts with the answers to the questions :thumbs: .
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,084 Guests (See full list)
