Help W/ Headlights
I'm looking to swap out my factory bulbs for my headlights/fog lights with a brighter white or blue aftermarket. So far I've looked into the SilverStar Ultras, Phillips and Wagner. The problem I'm running into is that I can only find the High beam (9005) and nobody makes a Low beam (H11) or a Fog Light (5202). I want all the lights to be the same style/color. Is there any other options or brands that I should be looking at?
This is the closest I was able to come up with for Low Beams and Fogs, Did not replace High Beams They do not match perfectly but are real close.
Plasmaglow Bulbs ~ Putco foglight Bulbs
http://www.stylintrucks.com/parts.aspx?partfamilyid=6040
http://www.stylintrucks.com/parts.aspx?att...rtfamilyid=5591
Thanks guys for pointing me in the right direction........now I just need to decide if I want to go with a White bulb, or Blue. I'm kind of leaning towards the Putco, just because the make all the types of bulbs, but then again PIAA makes a good product too.
Does anyone have experience with the PUTCO 360 LED lights? I'm considering some for my turn signals and tails but I dont want my truck to think that the bulbs are burned out because they are aftermarket LEDs. I hate when the turn signals blink too fast because they think bulbs are burned out.
EDIT: Here is a link http://putco.com/product/LED_360_Replaceme...art/233157R-360
I'm looking into buying the Putco LED back-up lights......I'll gine you some feedback when I get them.
Would these bulbs be a big improvement over the weak factory bulbs? I'm considering adding some cheap driving lights under the rear bumper and connecting them to the trailer back-up light wire.
I did this on my old 99 and it was a big improvement especially on rainy dark nights or mornings. Most of the cheap ($15 to $25) light sets you can find at Wal-Mart or the various chain auto parts stores have decent beam patterns for this type of use and they have 55W halogen lights. By connecting to the trailer wiring harness, you don't have to dig into the harness for the factory lamp assemblies.
I believe that you have to throw a resistor on them as well (unless the resistor is inside the base). My tails needed a resistor to flash properly. (before I changed them out entirely)
i have had the putco 360 LED lights for my turn signals, easy installation and they were brighter than the stock bulbs (plus looked nice too) however i don't have any pictures of them since i rearended someone and the lights were damaged. I have currently installed the putco led lights (blue) for my DRL, and i have Mtec 5800k blubs (blue in colour) for my lows and fogs. Mtec makes highs, and lows, and fogs for every gm model from atleast 2000. I picked them up here for about $65 a set. hope this helped.
P.s when it comes to blue or white colours for the bulbs, i had whites in and didn't like them, because its not the same white you'd get if you were driving with an actual HID kit installed, so i chose blue. Here's a couple pics.
The one picture is just the light of my low beams shinning on the ground next to mrdmax's truck. Notice the colour difference between the Mtec xenon bulbs and his stock bulbs. Then theres a pic of lows and fogs on and then the blue DRL's
http://s709.photobucket.com/albums/ww98/goodtyler/
I'm surprised nobody mentioned HID's. I would just get a set of those for your lows and fogs. You can pick up a set for nearly the same price as aftermarket bulbs on eBay and the improvement will be miles greater.
however putting in an HID kit will void your warranty for your truck( the headlight warranty). Just something to think about since this will be getting done on a nnbs
