How To Change Headlight Bulbs In 2008 Suburban
Good luck. The hardest part for me was getting the two fender bolts that hold the bumper fascia up. They're the ones that the video shows how to remove so that you can get to the third headlight assembly bolt. Reaching up from below with a long extension was difficult. I got better access to the fender bolts after I loosened the plastic fender liner. I think I could have accessed the third headlight assembly bolt from the fender liner and I wouldn't have had to mess with the fender bolts. When I do the other side, I'm going to try it that way first. Cheers.
  • 1 year later...
I did this in less than 5 minutes!!!! I was frustrated with the whole front end removal and saw another post about taking the air-filter top off. So, I took a flat head screw-driver and removed the clamps on the air intake sensor and removed the air filter box intact by pulling straight up on it. once that was out of the way, instant access to the back of the light assembly. Swapped bulbs, put air filter box back in and reconnected the sensor and done!
I hope this helps someone else!
    KJEK
    KJEK
  • Who's Online   0 Members, 0 Anonymous, 481 Guests (See full list)
