Crazy Clown's 10,000th Post Thread.
VMax2007
Took ya long enough Jim.
Hey, what's your opinion on the Bailout anyway? :lol:
Oh boy, don't get the crazy clown started down that road again... :fume:
Congrats Jim! :sigh:
Congrats! Thats alot of wasted time! LOL I`m strugling to get 500 just so i can get rid of the newbie "enthusiast" crap!
Free posts FTW!
Congrats
Holy sh!t, you have 32 posts per day...
Do the math :fume:
Jeff, Jim, his gonna pull your post ho card by Valentines Day :sigh:
Same here..congrats (and keep the clown,I think I'd miss him)
HA!
Thanks Jeff.
I have no opinion on the bail out... but I do like to push the buttons of those who do!
believe that? :sigh:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
