Are "Huskies" the only molded flap for the HD's?
I'll be needing mud flaps for my truck, and I really liked the molded ones on the my 1500 that I got from the dealer.  Husky makes a molded flap that works with "factory flares"...  Are there any other brands I should look at??? Does anyone have the Husky flaps???
Shaners,
I had a #### of a time finding molded mud flaps that would 1) work with my Bushwacker street flares, 2) fit well, and 3) that I liked!  I wanted the husky's, and I took a chance on ordering them, but they didn't fit right on the bushwackers.  They were a really nice looking setup.  (I almost wish I would have gotten the factory flares so I could have used them).  I ended up with some Ultimate Fit Powerflow flaps from the Sears Automotive catalog.  They were made for the factory flares, but I was able to make them work on mine with a little trimming.  They are a two piece flap.  The main part is hard plastic and the part that actually molds to the flare or truck is rubber.  They bolt together and then you attach them to the truck.  I don't remember off hand if the holes lined up with the factory hole for the fender flares or not, but i had to drill a couple holes for mine.  I'm happy with them, and they work well.  Here's some pics of them.
http://tommy3z71.homestead.com/mudflaps.html
Ryan,
I think I asked you this question when I was buying the Westin bars for my 1/2 ton.  There is clearance for the bars right??
I can see that Tom's works well with his Westins and I know the factory flaps without flares work, because that is what I had on my old truck, but how about Huskies, factory flares and Westins???
Thanks,  Shane
Those Huskies do look nice, especially against the black flairs,  I wonder what they would look like painted....  (my flairs are painted)  Hmmm...
Shaners
I have black westin nerf bars and the huskys fit fine.
Ill try and dig up a pic to show you the clearance.
Ryan,
I found a couple of good pictures on your site...  thanks!!!
There actually looks like more room than I had with the the GM molded flaps!!!
Nice pics too...
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
