Odb2 Port
08BlackSierra
Can the odb2 port on a 2000 sierra be replaced? And is there a way to test this plug. I have a service engine light on my dads truck. But when we plug our scanner into it, The scanner wont connect. The scanner works fine in all of my other cars/trucks
does it even turn on?? if not... you need to check your cigarette lighter fuse. it uses the same power source as the connector
+1
As asked previuosly... Does the scanner show anything?
Obvious things:
Plugged in securely
Try wiggling the scanner connector
Are any of the pins on the OBD port misaligned? Pushed back out of their sockets?
If still nothing..... I'm at a loss.
Obvious things:
Plugged in securely
Scanner acts as if its connected to nothing. Wiggling does nothing, Pins appear to be fine
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
