Sun Roof's
i have a 2006 gmc z-71 crew cab. i want a sun roof put in. can i get one installed after market, but work and look the same as factory???????? thanks ed......
Aftermarket sunroofs will never fit or work the same as OEM sunroofs.
Adding an aftermarket sunroof to your truck will decrease the value of it, since they are prone to leaking.
Thanks for the reply....ed
Also, factory sunroof equipped trucks most likely have additional reinforcements in the roof structure to keep the already flimsy roof form caving in upon itself. Sunroof ads weight.
Hey Ed,
While I kind of agree with the other guys here on the board about the possibility of leaks, if you really would like a Sunroof, I think the best thing you can do is find a Donor Truck that had one to begin with from the factory....basically of course you'd still have to make the whole in the roof....but by getting the parts from a Donor Truck you would better your chances of a factory like install, basically you could get the Headliner, Overhead Console, Mounting Braces, and of course the Sunroof Assembly, and also the DRAINS! thats' probably one of the most important things! It may take a little more research and time in gathering your parts, but the trucks are out there.....and with a reputable shop, you can probably have a factory like install!
Thanks guys, I think on my next truck I will get the sunroof option.
Ed.....
Preferably one without the "w". :thumbs:
If you really want a sunroof, I would let somebody install it professionally. There are companies who specialize in this and some even offer power sunroofs that slide and tilt just like factory units.
Keep in mind that factory installed sunroofs have drain holes in the frame and also drain tubes which carry rain water ways from the sunroof trough. Installing these tubes may not be an easy task.
Preferably with another "d", oh, and how do you keep a roof from forming in on itself?
:thumbs:
you could go OEM for the sunroof, but I would vote for the Webasto Grand View Sunroof:
http://www.truckinweb.com/tech/body/0713tr...rado/index.html
That is what I am going to have installed (eventually) by Classic Soft Trim. I also inquired about having a lifetime warranty added to the install to guard against leaks, breakdowns, etc. I personally do not care about the value of the vehicle for 2 reasons: 1) I am close to paying this off and I dont trade vehicles at the dealership 2) I plan to drive this sucker into the ground. If you have the same outlook on your truck, I would say to do it and have it done by Classic Soft Trim. Most guys here have either dealt with or heard of Classic Soft Trim. If you dont want to go with the Grand View Sunroof, look at either of these:
http://www.webastoshowroom.com/08ChevySilv...oCrew_H640.html
http://www.webastoshowroom.com/06chevrolet...lverado790.html
Ironically, most of the OEM sunroof parts themselves are from Webasto.
I say do it, but it is ultimately your call....
  • 2 months later...
The truth about sunroofs.
OEM roofs fail and leak just like aftermarket.
Parts are not available for OEM sunroofs. Glass, motor, switch. That's about it. Out of warranty repair is a complete replacement, about $1500.
Aftermarket roofs do not devalue a vehicle, they meet NADA requirements.
Do not try to install an OEM salvage roof!
Find a good, honest aftermarket installer. Learn about the products and meet the installer.
Carry on!
Classic Soft Trim are leather installers, don't let them install your sunroof! Find a webasto dealer!
Carry on!
Sunroof in my wife's 04 Impala works beautifully and has never leaked a drop (4.5 years).
Same goes for the sunroof in my truck (2 years).
I installed a power Webasto in my 03 and it worked flawless for more than 5 years without leaks. I loved it. It cost me $750 with a trim ring on the inside, but for $1100 I could have had the headliner tucked for a little cleaner installation.
I wouldn't hesitate to use them again.
Steven
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,143 Guests (See full list)
