5.3 Liter Flexfuel Ecm And Regular Ecm
MY TRUCK IS FLEXFUEL ,I GOT THE HYPERTECH MAXENERGY ,AND A TIME AGO I SET THE ECM UNIT TO REGULAR GASOLINE (BUT USING E-85) THE TRUCK FELT THE DIFFERENCE ,LOSS OF POWER.
SO I PUT IT BACK TO FACTORY SETTING.
THE ECM ON THE FLEX FUEL WORKS BASED ON FILLING UPS (MORE THAN A CERTAIN AMOUNT OF FUEL IN THE TANK,IGNITION OFF AND 11 MILES TO DETECT WHAT KIND OF FUEL IS ON THE TANK ,AND THEN CORRECT THE TIMMING ,FUEL AIR RATIO ETC...
MY QUESTION IS :
IN ANY WAY ,COULD THE HYPERTECH PROGRAMMER MESS UP THE ECM FACTORY PROGRAM WITH THE IGNITION TIMMING,AIR FUEL RATIO ON FLEX FUEL SYSTEMS?
WHY DO THEY SAY THAT IT WORKS FOR FLEX FUEL ? WHEN THE PROGRAMMER IS SET TO REGULAR OR PREMIUM GASOLINE ON NON FLEXFUEL VEHICLES ,IT'S DONE ,IT'S OK ,BUT WITH FLEX FUEL VEHICLES IT'S DIFFRENT BECAUSE THE ECM RECALIBRATES THE TIMMING,AIR-FUEL RATIO ,ETC...EVERYTIME THE TANK IS FILLED UP
AM I CORRECT?
TKS
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
