This Is What Gm Needs To Invent..
Kodiak450
You're driving along the road, or highway and then all of the sudden a message comes up. Sort of like "Danger Will Robinson". (Warning, warning, rice burner detected in 500 yards, situation criticial, rice burners detected in both lanes, deactivating 4 of the cylinders, so you will not feel cheated of power"
:uhoh::bs::P:P
I think you have this all wrong Dave :bs:
Wikipedia - "More contemporary use of the term rice burner, along with the prefix ricer, has taken on an alternate pejorative meaning for an automobile that has been modified to give impression of high performance, but does not necessarily have any high-performance capabilities."
A stock Toyota Camry & Lexus are not rice burners!
Huge Difference :uhoh:
A stock Toyota Camry & Lexus are not rice burners! These are rice burners...
I call :P
Rice is rice, no matter how it's packaged. :P
I think you have this all wrong Dave :P
Huge Difference :bs:
I call :P
Rice is rice, no matter how it's packaged. :D
:uhoh:
Now as for ricers. You could maybe make the argument that not all Toyota drivers are ricers.
Semantics I guess :P
I call :P
:uhoh:
Yes, they are, and so are Scion drivers/owners. :D
I call :P
:uhoh:
That was bait ><>
That was bait ><>
yep, clown bait. :P
edit: 12,000 posts...woohoo!!! But no more wrenches! :bs:
I didn't want to single anybody out . . . :uhoh:
That was bait ><>
yep, clown bait. :P
Wow!! Seems like yesterday Jeff passed Wingnut
:uhoh::bs::P:P
:P Why do you feel the need to buy software for this when all you need is your ears???.... You can usually hear a true rice burner at least 500 yards and further... :D
:bs::P:P:P
:D Why do you feel the need to buy software for this when all you need is your ears???.... You can usually hear a true rice burner at least 500 yards and further... :D
+1!!
And Jeff, maybe you've run outta room for more wrenches? :uhoh:
OMG a scion, thats the worst to get stuck behind. I often debate whether or not I can get out an push my truck faster then a scion. That XB thing is the ugliest thing I've ever seen! Looks like a refridgerator with spare tires on it. Some people just have no regard for themselves. I would be so embarrassed to ride in one of them.
Hey if you don't mind, could you please delete those rice burner pictures? I almost threw up when I saw those pictures. Thanks..
Per Dave's request (now that you actually know what a real "rice burner" looks like :uhoh:)
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,355 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
