Bbp Tuning
coop
Guys,
Don't know if any of you that are somewhat near would like to join in so I'm posting this here. Lately, I've had a lot of local guys mention wanting their truck/suv's tuned. I'm going to try and see how many are truely interested in this. We need 10 $50 deposits in order to secure this tuning date. Upon getting the $50 deposits, I'll get up with Justin to set things up. I figured I would post this up for any guys who are semi-local that may also want to jump in on the deal. There is no set date yet, nor a confirmation that he is coming. This will all depend on the turnout that I can gather. I am most frequently on GMFS. If you are interested, post in the main MB tuning thread there!
http://www.gmfullsize.com/forum/showthread.php?t=133883
Tentative List: February 6-7
PAID:
1. Madmedwyn
2. EarnhardtZ71
3. Chris04
4. Treihydral
5. 02 Chevy
6. Chris N.
7. Sam
What is the final cost?
$250 including deposit. Additonal cost if you want new replacement ecm/tcm. Check out
Blackbear Performance
This does need to be posted in the fullsize section
Edit: see ya beat me to it. :thumbs:
