Heater Core Connections
dcmargush
1999 Silverado 2500 (4wd, 6.0L)
There are plastic quick connect fittings used to connect the heater hoses to the heater core. Does anyone know what tool you are suppose to use to get these off? Is there a GM or a Snap on, etc part number?
I have tried the generic AT and AC tools and they don't seem to have long enough lips to retract the fingers inside the connector.
I know someone had suggested just removing them and extending the host and putting and a good hose clamp on them, but I still need to take it off.
thanks
Doug
  • 8 months later...
thanks
Doug
I'm having the same issue, is it safe to hook it back up without that stupid connection piece? I was told there is a check valve inside that white piece. I was also told just simply take a hack saw blade and cut the old broken piece off.
Has anyone been running this way and is there any risks?
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 496 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
