Key Won't Work In Doors...
ktuimala
I just bought a 2003 Yukon XL from a good family friend. Everything worked during the test drive and inspection. However, this morning I found that my keys do not work in any of the doors nor does either of the key remotes unlock the doors. When using the remotes the dash flashes and I hear a click, but the doors won't open.
I had to call a local garage to come unlock the door with a wire rod. When he got the rod in the door, he tried to hit the unlock button, but it did not work. Once he got the lock flipped the alarm went off and we had to put the key in the ignition and start the Yukon to get it to stop.
Following the repairman unlock the remotes will occasionally lock the car, but won't unlock it at all. Occasionally the automatic unlock button quits functioning on the door. Even more strange is that both of my door locks refuse to turn.
How can this happen overnight? Seems electronic to me? Have any ideas? I have to leave my key in the ignition to ensure the doors don't lock!! It is very aggravating and unsafe.
Welcome to GM-Trucks.com!
The key locks in the door could just be seezed. That happened to my '02....a little WD-40 freed them up.
And regarding the remote, is it possible that the battery in the remote is on it's way out.
it does sound kinda weird given that it worked yesterday, but you just never know.
Thanks for the tip.
I have sprayed WD-40 in both locks for the third time today. I have also been jiggling the key in the locks, but it quite literally will not budge. Perhaps they are just that seized.
Both remotes cause the parking lights to flash and the dash to flash when the lock button is pressed on either remote. I can hear a click coming from somewhere under the hood/dash when the unlock or lock button is pressed on either remote.
I figure it could still be the batteries, but both remotes, lights flashing on dash? Anyway I will go dig out a battery that I know is working and give it a try.
Thanks.
I found a new 2032 battery. Replaced the battery in one of the remotes. I still get the same results.
It is almost like the truck doesn't recognize them anymore. However, it has to recognize them if the dash lights up and parking lights blink when I push the lock and unlock buttons.
It sounds like your key is messed up... is it an original key? Are there any other keys you can try?
Does this year model have the computerized ignition key or not?
Just because it's working the ignition, that doesn't mean it doesn't have a defect that's keeping it from working the door locks.
It's possible that one of the door locks is jammed, possibly from using a bad key... and the solenoid is sticking, thereby explaining why the keyless remotes aren't doing what they're supposed to... in other words, when you press the lock/unlock, the system is detecting a stuck solenoid (because the lock mechanism is stuck) and it's therefore not moving any of the locks.
I assume you've contacted your friend to ask if this rascal has done anything like this before? :thumbs:
I am convinced the locks are seized now, but I will check with someone who knows what they are doing in these matters about the keys not working for the lock due to a defect.
I also just discovered that the remotes are part of a valet starter package that the original owner installed. It is a model 562T. This might explain a few things since the previous owner let the battery run dead.
Anyone know anything about problems that could occur from a valet remote starter after a battery runs dead?
Also, previous and original owner state no issues with remote, but they did admit rarely if at all using the keys to get into the vehicle.
Is it possible that someone changed the ignition switch, and your doors and ignition are now keyed differently?
You could take it by the dealership and get them to duplicate the actual key that the VIN specifies... then see if it will open the doors.
If it does, you might find that someone has changed the ignition at some point, and then only used the remote opener to get into the vehicle.
I can't see any reason why all of the door locks would seize up... (did you check the lock on the rear gate?)...
It still seems that your key is the wrong key for the doors.
Dan
Thanks for your help on this issue. Asking the dealer for a new key is the best bet to figure out what is going on. The lock doesn't budge a mm when I attempt to turn the key the lock. The strange thing is the key has a GMC logo on it so, if the ignition was changed, the previous owner was given GMC style keys. I just can't figure out why they wouldn't have the door keys changed.
Anyhow. Now that I know I have a remote starter I have a likely direction to go with the remote issues.
I've had my remotes work on my 03 before but not with the key. Lubed the locks and keys worked. Had to do this several times though till they loosened up enough for the key to work. Just had my battery going dead in my remote and key would only work in passenger door. Guess it's time to lube the locks with WD40 again.
