I personally like the looks and sound of the Gibson Extreme system. The only thing that made me think twice was having to re-locate the spare. But, from what I hear, that's not actually necessary.
Edit: I did some footwork for ya
I have had a couple of Gibsons. they were both single side 3" exhaust. They were actually pretty good. They are not real loud but have a decent rumble to them. :D
Don
IMO, Gibson is OK on the GMT 800's or anything w/o AFM. The sound is not really that good and I have experience from 2 different Gibson kits on my 07 NBS 6.0 silverado.
I will suggest the Corsa however. Very high quality for not much more than Gibson
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
