Which Fuse
Hello All,
I took off my driver's door panel and upon reinstalling it, the left side of the truck seems to have blown a fuse. The driver's window does not move, the mirrors don't work, I can't use the fob to unlock/lock the driver's door and the interior lights do not come on when you open any of the doors, but they do when you use the fob. I have replaced the fuse for the DDM (driver's door module) and that did not fix anything. What other fuses should I be looking at? By the way, it is a 2004 Suburban.
Thanks for the help.
Hello All,
Did you make sure all of the wires are connected.
You sure you didn't just forget to plug something in all the way? :dunno:
That would be enough to piss him off. :sigh:
Well, I've got personal experience in this area... :lol:
whats up with your truck?
Huh? Nothing new, currently?
I have double checked all the connections and they are all secure. I have looked in the owners manual and there is not a fuse that seems to fit everything that has stopped working.
that is going to be a problem. the features that are not working are on different fuses...
Hello All,
question though: What was the reason for you taking off the panel in the first place???
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
