dlewis1111 Posted January 19, 2009 Posted January 19, 2009 I am researching the addition of factory fog lights on my 08 LT. I need a favor..... Somebody look under their truck and trace the fog light wiring from the lamps as far back as possible and note ANY of the numbers on the wiring, and the colors if possible. Also, if somebody with a white truck can get the part numbers off of the bumper extensions that would be awesome. They are visible on the extensions from under the truck on the left / right hand sides. Somebody posted the complete wiring schematic on this forum, and I was able to figure out that the fogs are "wired" with the exception of the headlight switch, the harness, and the lamps. There is even a fuse and relay already installed under the hood. I just need to tie into that with hopefully some factory wiring. The dealer here is no help though unfortunately. Thanks in advance.
SLESierra Posted January 19, 2009 Posted January 19, 2009 GM was going to release a kit for this install so I would say to check that first as it may be a cheaper route to take.
matt3 Posted January 19, 2009 Posted January 19, 2009 GM was going to release a kit for this install so I would say to check that first as it may be a cheaper route to take. I've been hearing that since I got my 08 Sierra in March of 08. I doubt with all of their financial worries that, they'd take the 10 minutes and come out with a kit. I'd love to get some fogs for my Sierra. If anybody has some inside info as to when/if a kit is really going to be released, I'm sure that info would benefit many members here
tobias Posted January 19, 2009 Posted January 19, 2009 This about the best info regarding this topic on this site. Most anything you'll need to know is here, you just have to search for it. http://www.gm-trucks.com/forums/index.php?showtopic=76764 http://www.gm-trucks.com/forums/index.php?showtopic=77941
