Adding Tpms To 06 Cc
I own a 06 Sierra CC and I have added steering wheel controls and reprogrammed for DIC. Yesterday I added the PDM that has TPMS on it. I got the TPMS running, the light comes on on the dash and with the cold snap down here I got a Check Tire Pressure message on the DIC as well as the little light.
My problem is that I cannot see the individual tire pressures on the DIC. Do I need to get a new VIC number for this? Is it possible that the PDM is not programmed to show the individual pressures? Should I get a different PDM?
Any help is appreciated!
  • 2 months later...
  • 1 year later...
