Taillight Covers
I'm going to get some solid blackout taillight covers for my Blazer.  I'm not sure which ones to get.
Ventshade - $39.99
GTS  ---  $72.00
Does anybody have these, how do you like them?
Anybody have any other suggestions of other brands?
Are the GTS THAT MUCH better than Ventshade that I should pay that much more?
Thanks for ANY info in advance.
I haven't had either of those but I did have Ventshade VentVisors and they were really good quality.  Although I see alot of people with the GTS's.
Have you considered tinting your stock tails?  I've known a few people that have done that and it turned out really good.  You could use a product called Nightshades which I believe you can buy at Autozone.   What you do is sand them down, spray the tint on in coats until you get it to your desired darkness, spray on clearcoat, then wax and polish.  Then again if you are wanting to completely black out your tails (to where they aren't even visible when on, I'd just get the covers.)  jmo.
Thanks for the input.  I bet that tinting them would look realy good if it's done right.
I have the Ventshade VentVisors too, and had them on my old truck.  I like them alot.   But I always heard that GTS was the best light cover you could get, I heard you could see them better when they lit up through those, but they were still blackedout good when not lit up.
I went ahead and order the GTS tonight.  Tom found them for $42.90 on Truck Performance.com with free shipping until 11:59p.m. tonight, so I jumped at the chance at got them.
I'll post a pic or two once I get all of this done.  I've already added a bugshield and VentVisors, once I get these all I'll have left is mudflaps for a while.  Hopefully the 2"lift will be Christmas. :cool:
