Gm R4 Compressor Pad Block Fitting
pav1
Hello friends at GM Trucks,
My truck has a ZZ4 motor with the serpentine belt kit and R4 compressor. The compressor has a 3/4" suction hole and a 5/8" discharge hole on the back. It is the step down type that requires a step down adapter or different size stat o seals. I can't find a pad block adapter that will fit this compressor. If anyone knows what part(s) I need, I'd appreciate it. The hose fittings are #10 on the suction side and #8 on the discharge side.
Numbers on the compressor:
88964849
15-20184
022781326
