Fuel Guage Erratic
jhm
For a few months my fuel guage has acted strange. Sometimes after filling up it will show empty, other times I start the engine and it shows empty UNTIL I put it into drive or reverse. Other times it will move around before settling in the right level. I am thinking could something in the cluster (electrical) be causing this. I dont want to move the bed and replace the pump/sending unit then still have the problem. Any techs ever see this?
I have a 99 Silverado doing the same thing, not sure if its electrical or just the float stickin'. Does it when its full, after i use 1/4 then it seems fine, same as you though low fuel light when full, when you drive away its ok.
I been setting the trip odometer when i fill up. I dont trust the guage now. Just dont want to spend $$$ for new pump,float if it is not the problem. I was thinking of pouring some Techron in the tank to see if it cleans the float assy.
I had tried running Marvel Mystery oil in the tank for a couple of tank fulls thinking same but didn't help, worth a shot though, may help you, doesn't hurt.
I took a 900 mile trip this weekend. On one fillup, the gauge stayed at full for 155 miles and then took about five minutes to go to empty. I stopped, turned off the truck and started again and it stayed at empty. The "distance to empty" showed ---. I stopped the truck for about two hours and it's been fine ever since (500 miles) and two fillups. Very strange.
I had a similar problem, it turn out to be a sulfur build up on the float. I use fuel injector cleaner in the tank and it dissolved it. I add it every 3 months and problem has never come back.
Talked to my buddy who's a mechanic for Chevy. He said the instrument cluster needs to be reprogrammed. He said he's seen it more than a few times.
I'll almost guarantee it's the sending unit. I had the EXACT same symptoms you describe in my '99. Dealership determined it to be the sending unit. I lived with the problem until I traded it in since I didn't want to pay the dealership what the wanted to fix it.
Did he tell you how that is done and what it cost? I would try it before replacing the fuel pump if it was reasonable money wise.
I wouldnt pay to change it out for the sending unit alone, of course if the pump was bad that would be different. I plan to keep this '01 another year or 2 so I could live with watching the trip odo as a back up.
No. Mine's still under warranty so I didn't think to ask.
Since you have an '09 and mine is a '01 it is probably different setup. Thanks for the info though, I can ask the dealer about it. Knock on wood, it hasn't acted wierd for a day now. Think I will put some Techron in for the next few fills and see if it helps, can't hurt.
:withstupid:
JHM, the Techron is absolutely the first step. Use the 20 oz bottle and run it at 1 oz per gallon. Do this for 2 tanks and if it is simply a sulfur build up you will be good to go and will be out about $20.00. If it does not work, you will have the cleanest injectors and combustion chambers in town.
Be sure and get pure Techron and not Chevron's fuel inj cleaner (with Techron).
We sell this product and see it work for this issue in many cases.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,156 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
