How many do you have??
Frank S
I was adding up all my posts from the top 4 forums i post at and it is
**2441 posts!!!**
Man, thats not that much. :(
**2441 posts!!!**
How did you come up with that number??? That's about 4 times higher than you show in the "members list"!!!
Shaners
He is talking about the total number of posts he has from the four different boards that he visits the most.
Zane
If you aren't impressed with your cumulative post count then my 1413 won't impress you very much.
Remember that it isn't the number of posts you have it's...........
Maybe it goes; it isn't the size of your........
Oh well, I don't usually post much but I lurk a lot.
Keep posting.
LT
Better watch it.... you guys are going to get The General all shook up and he going to start posting everything from his grades to the weather report to catch up!!! Just JK'n General......Daisy Duke rules.
Today was mostly cloudy and I was under a STS watch until 9:00. Nothing ever came though.
Tommorow: Periodic Rain.
Hold on, let me pull up my Report Card...... :biggrin: jk
