Autoride Shock Replacement
cduke123
I have a 2002 Yukon XL w/Autoride w/95,000 miles. I beleive that the shocks need to be replaced, but I don't use
or need the Autoride. My intent was to replace them w/heavy duty shocks, but I am finding out the it is not so easy.
I have searched but not found anything relating to a solution.
I understand that I can go w/different shocks, but I will have the advisory/caution light on all the time unless I can
change the resistance to 'trick' the system. I have also been told that I should talk to someone who can re-tune
the computer, but I have been unseccessful with that.
Any suggestions?
Thanks!
I can tell you that a re-tune will not stop the caution light. A tune deals with how the engine runs not how the shocks are read.
As for the need for resistors, does your truck have the DIC? If not you can just swap to any other shocks and you won't get a caution light. I am speaking from experience as I removed my auto-ride shocks and put in Bilsteins just over a month ago.
To test for the caution light you can disconnect the wires that go to the shock and see if you do get any caution lights. That will help determine if you need the resistors or not.
Have a nice day.
Bill
These folks are the ones that manufacture the Autoride shocks and componants for GM
http://www.arnottindustries.com
From previous threads their prices are softer than GM''s $400+ price
GMC Yukon XL Electronic Front Shock
GMC Air Suspension Parts - Yukon XL 1500 - 2000-2006 (4x2, 4x4) w/ Autoride Suspension
Base Price: $199.00
Total 2X: $398.00
GMC Yukon XL Electronic Rear Air Shock
Base Price: $199.00
Total 2X: $398.00
Total: for 4 shocks $796.00 -------GM - $1600
