First NASCAR Chat Update
NewbieZ71
Well, I thought I'd let everyone know we had a nice NASCAR chat session tonight!  Sorry everyone wasnt there.....to recap.....
Chat started at 10:00, couple of late stragglers (Tom and The General) into the room but I forgave them.  Topics started flying, all NASCAR related of course...discussed everything from soft walls to restrictor plates... around 10:30 Dale Earnhardt Jr. came into the chatroom and was a delight! Talked all about NASCAR and his win at Daytona, gave everyone of us official pit crew uniforms.  He was one short so MountaineerTom gave his to General Lee... Junior thanked Tom for "covering for him" as he put it and is going to drive one of the suits by Toms house when he is in Darlington next time and stay for dinner.  KansasKid's girlfriend kept getting everyone a beer. It got a little ugly when Jimmy Spencer showed up and kept complaining that the chat was a conspiracy and just setup to make Junior look good.......Tony Stewart  logged on about 11:55 but kept hitting the command "Tony Stewart whines again" which got REAL tiring so we all thanked Dale Jr. and left at about 12:30 about the same time we heard Shaners alarm clock go off to get him up for work....
Anyway, maybe everyone will come next week.
(Edited by NewbieZ71 at 9:53 am on July 17, 2001)
Funny thing is, me and Tom were there before Newbie.............
Mark Martin logged on at 12:29 and offered newbie a lifetime supply  of a certain pfiser product.........:wink:
