Sirius Radio Conversion?
I have 2008 Silverado and I have multiple Sirius accounts. I am wondering if they have came up with something to allow me to use my factory controls?
Even though XM merged the channels you get with XM are still terrible. PLEASE HELP!!!!!
THANKS!
Sirius "was" going to introduce a tuner for 07+ GM trucks, but almost two years later, it's still not out, at least not since I last checked. I think the merger killed the new product offering. There is an adapter you can get from TSS.COM to use your XM antenna with a Sirius tuner, if you are able to find one. I got tired of waiting and put in a Kenwood deck with a Sirius tuner. Sounds way better than the factory head unit with the amp and speakers I have.
Ok. Thanks for the info
