Well, the mag chloride has permanently corroded the chrome trim on my grill within 6000 miles on the truck. Nothing will remove this. You can look at the truck from 10 feet away and see the pock marked corrosion. Amazing stuff this mag chloride is !!! :D
Sure glad we don't have that stuff here.
I'd rather have rust holes in my truck than bullet holes. :D
Hell I am surprised you don't have bullet holes in your truck :D:thumbs::D
I'd rather have rust holes in my truck than bullet holes. :lol:
If he came down here and spent the Summer... that would probably solve itself. :D
