Power Window Kits
Need to put PW on my 2007 GMT 900 Silverado, it came with PDL but not PW's. Which aftermarket one is the best ?
I know this isn't EXACTLY what you were asking for but... I think the best move would be to buy power regulators (with motors and door wiring) from a salvage yard and then wire with two relays per side to a centrally mounted window switch. Pretty easy wiring job and you would have OEM hardware. Aftermarket systems I have seen are pretty light duty. Not sure how long they would actually last. REGARDLESS of which way you go, stay away from the units that simply install over the existing regulator in the place of the window crank!
Bump- Anyone know of a good aftermarket power window kit ?
I don't have time to go to a salvage yard and get everything.
