2000 Gmc Safari Keyless Entry Receiver Issue
Hello,
I was hoping one of you here will be able to help me trouble shoot my problem. First off, I have a 2000 GMC Safari and the issue looks to be with the remote keyless entry receiver. I'm pretty sure it's not the individual remotes because I've checked and replaced their batteries and when I go to try reprogramming them(with instructions found on another post here), when I do step 7, Steps 7.1/7.2 never happen.
1)With the driver door closed, hold down the power unlock button on the door panel.
2)Turn the ignition switch to the ON position
3)Turn the ignition switch to the OFF position
4)Turn the ignition switch to the ON position
5)Turn the ignition switch to the OFF position
6)Release the power unlock button on the door panel. The remote control door lock reciever will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1)Locking the doors
6.2)Unlocking the doors IMPORTANT: All extra transmitters must be programmed at this time. When a new transmitter is programmed it will deactivate the old transmitters.
7)Hold down the lock and unlock buttons on the transmitter until the remote control door lock reciever will respond in the following manner:
7.1)Locking the doors
7.2)Unlocking the doors
8)Repeat step 7 for each additional transmitter
9) Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
So thinking the receiver is be bad, lead me to the following questions:
1) Which Fuse(s) control the RKE module?
2) Where is the RKE module located? And how can I confirm there is a problem with the receiver before I purchase a replacement?
3) Any other tips you may have :D
Any insight you can provide to help find the problem would be greatly appreciated. (especially if it keeps me from having to take it to the dealer to fix $$)
Thank you!
Well, I guess stranger things have happened. I was eventually able to program both remotes but not where van and remotes have worked for years. Seems like there may be something causing interference because I after I moved my van 20 feet away from my house/garage, the remotes and receiver work. At this point I'm not sure what can be causing the interference or if interference is the real problem. All I know the situation is weird especially because it's all of a sudden.
  • 2 years later...
Have you had answers to your original questions?
3) Any other tips you may have :)
I'm faced with a similar dilemma with a 98 GMC Jimmy.
thanks!
Lol, I might be able to shed some light on this... A few Christmas's ago, someone here got a remote control toy truck. Strange things started to happen to my lock system and my neighbors across the street too. Turns out that the remote control truck was put away and not switched off. Switched it off and Presto, all out problems disappeared.. ;)
    JimmyB4
    JimmyB4
  • Who's Online   1 Member, 0 Anonymous, 656 Guests (See full list)
    • Are you going to take long trips in it?  If so, try out the seats in the various trims. For me the lower trim level seats were not comfortable.
    • I have a 2016 that I bought new and still own. I'm around 129,000 miles now. The biggest problem was a transmission failure about 2 years ago around 95000 miles. No warning, just failed while driving down a back road. A reman GM transmission installed and it's been fine ever since. A few other minor problems along the way. I am in no hurry to replace it. It's been paid off long ago and do plan on driving this as long as I can.   I will admit I am leery about all the additional electronics in the newer models and feel that it is just more potential problems. I think there's actually more than I would have wanted in this 2016 but so far so good. I think even if something major like lifter failure happened, it would still be cheaper to at worst, drop a new engine in than buy a new vehicle.
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
