killerbp79 Posted March 16, 2009 Posted March 16, 2009 i bought my truck with the lift already done, it is the fabtech 6" lift. the front end rides SUPER stiff, almost like there is no suspension. Is this normal? Can i do anything about it? Thanks
VR021302 Posted March 16, 2009 Posted March 16, 2009 Change the shocks to adjustable ones. The brand is all preference. I like Rancho 9-way adjustables.
killerbp79 Posted March 16, 2009 Author Posted March 16, 2009 huh, ok, you think the shocks will soften it up? Ill give it a shot...
VR021302 Posted March 16, 2009 Posted March 16, 2009 huh, ok, you think the shocks will soften it up? Ill give it a shot... They made a huge diff on my old Dodge, like night and day.
mattro Posted March 16, 2009 Posted March 16, 2009 if it sits level I'd check to see if the torsion bolts have been turned if you have them on your truck. That can make it stiffier but shocks will improve alot if they are shot
2000DV4.8 Posted March 17, 2009 Posted March 17, 2009 Before you just throw money at the truck by buying new shocks, can you get some pictures of your front suspension setup (CV/ball joint angles preferably).
J-man67 Posted March 18, 2009 Posted March 18, 2009 Exactly Dan.... Bobby, get us those pics and we can tell if your torsion-bars have been cranked (which WILL stiffen up your ride) or not. I am not too familiar with the lifts for your body style, but I do know that to acheive the advertised hieght of the kit, the manufactures had you crank the t-bars.
killerbp79 Posted March 18, 2009 Author Posted March 18, 2009 Exactly Dan.... Bobby, get us those pics and we can tell if your torsion-bars have been cranked (which WILL stiffen up your ride) or not. I am not too familiar with the lifts for your body style, but I do know that to acheive the advertised hieght of the kit, the manufactures had you crank the t-bars. ya i forgot these have torsion bars! i bet thats the culprit. i will get pix up tomorrow! lets say i decrank for ridability, how can i level the truck back up?
killerbp79 Posted March 18, 2009 Author Posted March 18, 2009 Heres the pix guys! and here is on of the torsion key, if you put your finger above the key there is almost an inch between the key and frame.
Ranger Posted March 19, 2009 Posted March 19, 2009 What pressure are you running in those tires? Dumb thing, but some M/Ts can be rock-hard at high pressures...I'd say yours should be around 35 psi. The CVs are a little high but not that bad (speaking from experience, my buddy has a 91 GMC 2500 and his CVs are almost 45 degrees off).
killerbp79 Posted March 19, 2009 Author Posted March 19, 2009 What pressure are you running in those tires? Dumb thing, but some M/Ts can be rock-hard at high pressures...I'd say yours should be around 35 psi. The CVs are a little high but not that bad (speaking from experience, my buddy has a 91 GMC 2500 and his CVs are almost 45 degrees off). dont know, but they are pretty full! Maybe I will try and let a little air out! Good thought.
2000DV4.8 Posted March 19, 2009 Posted March 19, 2009 Yeah the CV angles are pretty steep, but that's to be expected with a knuckle lift. CVs don't directly affect ride quality, they are just a good indicator of how your front end is set up. Your BJ and tie rod angles look to be just fine, so the stiffness isn't coming from being over-cranked (in my opinion, at least). Scott just mentioned what we all should've mentioned first, check your tire pressure and we'll see where we can go from there.
