dginn911 Posted March 19, 2009 Posted March 19, 2009 I am in the process of replacing my 4.3L V6 engine block (EFI) and recieve two different sets of lower intake manifold gaskets from the engine supplier. One set has all the water ports open, the other set has the Rear 2 water ports closed off. Which one should be used? I am assuming that the ALL OPEN ports gasket should be installed. Please Help! The vehicle is a: 1987 Chevy 1/2 ton Pick-Up 4.3L V6 EFI 2 Wheel Drive
Zembonez Posted March 19, 2009 Posted March 19, 2009 Some "universal" gasket sets have duplicates that fit different year models. Once you pull your intake, you'll simply match up the one that is there. Welcome to the ZOO!
pennzoil29 Posted March 20, 2009 Posted March 20, 2009 Some "universal" gasket sets have duplicates that fit different year models. Once you pull your intake, you'll simply match up the one that is there. Welcome to the ZOO!
