Fs: Jl Stealth Box 07+ Truck
I got a entire system I was going to install in my 07 Sierra denali but decided I just dont have time to do it even though the factory bose sub stinks.
JL audio Stealthbox $450 USED
Boston Acoustics GT40 amp BRAND NEW (only amp with big power and will fit in center console!) $200
MTX RE-Q BRAND NEW- Eliminates bose sound processor cutting base with volume $100
Package price $700 for it all.
Shipping is NOT included.
Please e-mail at [email protected] for fastest reponse
I have the stealthbox in my truck and its a great box. Awesome quality, not that cheap plastic or particle board.
TTT for a good system.
i want a stealthbox but don't want the little sub in it
If you want a JL Stealthbox and dont want the "little" sub you may want to check out the one they make for under the rear seat. It has two 10's..maybe small by some means but they are very very impressive. I have heard both. The two tens should satisfy just about anyones needs. The one that converts the center console is also great. Its night and day over the bose sub. JL has done great work on these for the trucks.
Wait, what "stealthbox" is this? My JL Stealthobox is under my rear seat and I have a 12" jl sub in it.
Sorry, it could be different for each body style and cab configuration. I was under the impression the used 10" in most of them. The two options from JL for the NNBS trucks are a single 10 in the console or two 10"s in a box under the rear seat.
i want the one that goes under the center console. but i need a something like a w7 in it. and i only use tens for response and lack of droning. i have invested quite a bit in my stereo and the w3 will not keep up with the rest of the stereo components. 6.5 components front and rear, center channel, alpine iva-w205, and theater amp. you look in my truck and it looks stock except for the tweeters in the back door. my wife didn't notice them for 4 months. so i need the center console or a custom made one
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
