Blue Smoke When Cold
Valve stem seals leaking.
+1
Common but not life threatening. More of an annoying thing than anything.
Is it something I should worry about / take care of? If so how?
Thanks for the reply.
It's a pretty benign problem.
Unless it gets bad and you notice you're burning a lot of oil, probably not worth the cost of a valve job. Was real common on the 350's and 4.3L.
Yup, valve stem seals. As long as it isn't smoking to bad (from your description, 30-60 sec, it sounds like it isn't horrible), I'd just keep an eye on your oil level and make sure that you top it off once in a while. Nothing more than that needed.
If you really start to burn through the oil and you want to keep the truck for a while (several more years) longer you could think about tearing onto the engine to replace the valves and seals. It can get pricey though if you take it into a shop...
Wouldn't that just make his tires flat? :lol:
:lol:
Only on the bottom Jeff. :lol:
